| DRILLS |
Special multiple diameter drills, such as step drills and subland drills are offered, which can carry out complex drilling and countersinking operations in one production set-up. Special double margin and drill reamers are used for the drilling of close tolerance holes in single operation. Oil hole / coolant feed drills are manufactured with internal ducts through which liquid flows to the cutting zone. These drills are suited to deep drilling and operations which require intense lubrication. We offer core and step core drills which are used for enlarging pre-drilled holes. The 3 and 4 flute design serves to correct both alignment and the concentricity of existing manufactured holes.
| REAMERS | ||||||
| SPOTFACE / COUNTERBORES | ||||||
| COUNTERSINKS / RADIUS TOOLS | ||||||
| SOLID CARBIDE / COMPOSITE | ||||||
| AIRCRAFT TOOLS | ||||||
| SPECIAL / CUSTOMISED TOOLS | ||||||
| >-home | ||||||
| >-quality assurance | ||||||
| >-quotation request | ||||||
| >-brochure download / request | ||||||
| >-jobs | ||||||
| >-contacts & distribution | ||||||
tel:+44
(0) 114 288 9444 • fax:+44 (0) 114 288 9894 |
